Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
07 Caliber - Screeching when AC is on
Old Sep 3, 2013 | 12:15 PM
Al in SoCal's Avatar
Al in SoCal
Question 07 Caliber - Screeching when AC is on
Hi All,
Came across the forum researching an issue I'm having with my 2007 Caliber (base model) - has about 80K miles and I've had it since 2008. When I have have the air conditioner on a screeching noise starts happening, especially notable when I accelerate from a stop. The noise completely stops when I turn the AC off.
A couple of questions:
1. Could this be a belt (I've never had any belt replaced yet)?
2. If it's the compressor - anyone have a guess-timate about costs to replace?
3. I'm thinking of buying used and taking it to a mechanic - are mechanics ok with that?
Any help and / or info is appreciated.
Thanks!
Al in SoCal
Old Sep 4, 2013 | 11:24 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum. It sure sounds like a belt making noise with the extra load of the a/c compressor. I would start by replacing it first. Also, make sure it is dry and doesn't have oil on it from a leak somewhere. That will cause them to be noisy as well.
Old Sep 4, 2013 | 05:29 PM
Hippo420's Avatar
Hippo420
replace the belt and make sure it is tightened properly. don't forget to check the belt after a couple of hours run time because they will stretch out a bit right off the hop. if it still makes noise afterwards, I would have your AC pump checked, the clutch pack could be seizing up
Old Sep 6, 2013 | 08:21 PM
lxman1's Avatar
lxman1
Site Moderator
It is a variable displacement compressor. It has no clutch. It turns all of the time as far as I know.
