Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Car runs cold
Old Jan 9, 2015 | 03:58 PM
Karl B Gillum's Avatar
Karl B Gillum
Unhappy Car runs cold
I installed 2 new thermostats on 2010 Dodge caliber engine run cold and no heat what should i do next
Old Jan 12, 2015 | 04:58 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
Does the temp gauge rise as it should?
Old Jan 13, 2015 | 10:01 AM
Karl B Gillum
No it gose less then half way. i also flushed the heater core. they should have never put 2 thermostats in that engine.
Old Jan 20, 2015 | 02:18 PM
lxman1's Avatar
lxman1
Site Moderator
Ours runs a little under the 1/2 under half way when up to temp. I am wondering if you actually have a blend door problem in the dash as to why you are getting no heat. In 2010, they switched from the tried and true cable actuated to electric actuators that tend to break from time to time.
Is the top heater hose hot after it gets up to temp on the gauge?
