Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Loose cruise control stem
Old May 18, 2016 | 10:55 PM
comdoc's Avatar
comdoc
Default Loose cruise control stem
07 Caliber cruise control stem on right steering column has become loose, and is flopping around. How can I gain access to mounting that secures it?
Old May 19, 2016 | 07:51 AM
lxman1's Avatar
lxman1
Site Moderator
You should be able to remove the plastic casing around the steering column. There should be a couple of screws on the bottom side that usually take a torx bit, like a T-15 or T-20.
Old May 19, 2016 | 12:04 PM
comdoc's Avatar
comdoc
Thanks lxman. Torx and 2 phillips head screws. I got access to the light switch assembly. The cruise control switch assembly is on the steering wheel assembly. No evident means of attaching the plastic pieces that enclose it. Do I have to remove steering wheel to get to it? Looks like the cruise control arm is broken, will need to replace.
Old Jun 4, 2016 | 07:00 AM
lxman1's Avatar
lxman1
Site Moderator
You should be able to pull the airbag assembly out from the front and access the CC switch I believe.
Old Jun 4, 2016 | 08:55 AM
comdoc's Avatar
comdoc
Thanks for all replies. Yes, the airbag assembly just snapped out. No special tool needed. A strange coincidence: radio reception failed after installing new turn signal switch, and putting it all back together.
Old Jun 7, 2016 | 08:13 AM
lxman1's Avatar
lxman1
Site Moderator
That is strange. The only relation to the radio/steering wheel is if you have the radio controls on the back of the steering wheel and that would have no effect on the reception, just volume control and station/input controls.
Old Jun 7, 2016 | 09:16 AM
comdoc's Avatar
comdoc
Thanks lxman1. Is it possible the aftermarket amplified antenna mast failed immediately after reconnecting negative battery terminal? How do I access the radio/antenna wire connection? It's the original radio.
Old Jun 23, 2016 | 06:59 AM
lxman1's Avatar
lxman1
Site Moderator
It should plug directly into the back of the radio the run behind the dash, then out into the inner fenderwell.
