Is there a correct procedure when changing the battery?
Hello, I'm sorry if this question has been asked before. I have searched for an answer on here but unable to find anything. My question, as silly as it may sound is, is there a correct procedure when it comes to replacing the battery on my Caliber SE 1.8 petrol. On my last vehicle (Peugeot 307) there was a certain procedure that had to be followed to ensure that the BSI unit wasn't 'fried'.
Is it just a case of disconnect the negative then the positive and put new battery on and then reconnect or is there something more I need to do? Also, apart from losing any stored radio channels, will the radio still work or will I have to put in a code?
Sorry if these have been asked before but it's better to be safe.
Thanks for any help/advice.
remove the negative terminal first, then the positive.
removing the positive first is not safe...if your wrench hits a ground source when removing the positive cable...its will create a direct short to grd.
