Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
2007 Dodge Caliber Ac Not Blowing Cool
Old Jul 21, 2019 | 08:20 PM
gregraschkejr's Avatar
gregraschkejr
Default 2007 Dodge Caliber Ac Not Blowing Cool
2007 caliber has freon in it new pressure switch the compressor doesn't have a clutch I keep getting low and high pressure errors even though it is at the right level
Old Aug 17, 2019 | 12:09 AM
lxman1's Avatar
lxman1
Site Moderator
I think it has a clutch, but it uses internal valving to regulate the pressure/temp, instead of cycling the clutch like most vehicles do. I know you can tell when the compressor kicks in on our 09 by the rpm and it vibrates a little more at idle with the a/c turned on.
Old Aug 17, 2019 | 12:36 PM
primem's Avatar
primem
please explain what a low and high pressure error is? You have manifold gauges and are measuring high and low pressures? if you have static and running pressures, post them.
did you fill the system with a can or ac charging machine. CAN filling is not accurate.
