Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
When does the governor work?
Old Nov 19, 2006 | 05:40 AM
ozzman18's Avatar
ozzman18
Default When does the governor work?
I drive on the autobahn all the time, over 5000 miles (in germany thats alot of driving) and usually keep it between 80 and 100mph. I've hit 105 but didn't want to do more not knowing about the governor. If it has one how does it work? Does it just stay at the max speed or does it shut down?
I have a sxt sport.
Old Nov 19, 2006 | 12:51 PM
Hog54's Avatar
Hog54
Default RE: When does the governor work?
The caliber doesnt have any governor that i know about?Not unless you had one put in.[&:]
Old Nov 19, 2006 | 02:56 PM
tupmeier's Avatar
tupmeier
Default soory double post
sorry double post
Old Nov 19, 2006 | 03:00 PM
tupmeier's Avatar
tupmeier
ORIGINAL: ozzman18
I have a sxt sport.
There are reasons more than a DCX engineer sitting around and going, "Haha, let's see how disappointed they will get when they run into the governor at 115 MPH!"
* Tires - Read that number and letter combo next to the tire size sometime. That is the load index and speed rating and they are to be read and understood together, not seperately. I've used this analogy before, a 75H tire would take a Lotus Elise safely to 130 MPH, but a 75H tire on our cars and you would be lucky to hit 100 MPH before tire failure.
* Glass and other items held on by simple silicone/urethane - The Porsche in the picture below blew their tire at 150 MPH (Nothing fancy by today's standards), but when it went sideways at 150 MPH, the crosswinds on the car sheared it's windshield clean off. Also this Porsche was going in a straight-line at 150 MPH when this occurred.
* Suspension, brakes, ABS, traction control, and steering - Everyone of these go hand and hand together. This alone is the main reason for speed governors. GM has an entire facility dedicated to the testing of these systems and what kind of speeds it can take that won't cause failure or pre-mature wear. Personally I wouldn't want to be on a track at 120 to 130 MPH with drum rear brakes (ie Caliber), been there, done that and scared ****less then. Nothing quite like blowing out a wheel cylinder boot at those speeds, losing your brake fluid and not being able to stop.
[IMG]local://upfiles/43270/5287E9C0B3334EFBB19DBFA708F8D3A8.jpg[/IMG]
Old Nov 20, 2006 | 05:17 AM
caliberlover07's Avatar
caliberlover07
Well the fastest I went in my Caliber was 175kms or 105 mph approx an hour on a highway in the summer on a long straight away. the photo below was taken by my brother on the first attempt. The only noise was really from the outside wind hitting the car. The speed limit on the straight away was 80kms. But because the car couldn't shift faster with the CVT tranny it seem to move so slowly when trying to go faster. We ended up not having enough road ahead and had to slow down. Here is the photo of my speedometer. I can tell you one thing though I highly doubt I will ever drive that fast again as it is too dangerous.
Also a video I found of someone in Canada here who tested how fast they could drive it. They didnt max out though, but got to about 110 mph
http://www.youtube.com/watch?v=kzjAtf59GEo
[IMG]local://upfiles/43591/D69AE026A27F486790CA186AD1A203ED.jpg[/IMG]
Old Nov 25, 2006 | 04:45 AM
mahal3680's Avatar
mahal3680
Damn, from the looks of your tach in the pic, you're almsot red lining! That can't be good for those little four bangers...next hing you know, KABOOM!
Old Nov 29, 2006 | 11:51 AM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
If you live in Ohio, the Governor never works [sm=exactly.gif]
Old Nov 30, 2006 | 03:05 AM
caliberlover07
ha good one.
Old Dec 1, 2006 | 03:34 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I'd bet the Caliber has a PCM like all the other "newer" cars. This is where the top speed governor resides, in a program within the PCM, it's not mechanical.
<edit> Look for one of the programmer manufactures to come out with a programmer for the Caliber. The programmer would allow you to raise the speed limiter. Probably SuperChips or HyperTech would do it first.
Old Dec 2, 2006 | 05:15 PM
caliberlover07
wouldn't that void your warranty?
