Towing
Old Apr 10, 2007 | 10:32 PM
rrnkp's Avatar
rrnkp
Default Towing
I have a 2005 2.4L Caravan and was wondering if it would be able to pull a small pop up camper like 1200 Lbs.
Old Apr 11, 2007 | 10:40 AM
mazdab2600's Avatar
mazdab2600
Default RE: Towing
check with your dealer or owners manual and see what its/they say
1200lbs isn't much but on a 4 cyl it might be to much
put a tranny cooler on it bigger than they recommend
with my 3.0 i pulled a 2001 starcraft close to 3000 lbs maybe more loaded and had the rv place put a larger cooler on4 yrs later no tranny problems
the killer for most tranny's is heat so keep it cool
Old Apr 15, 2007 | 11:07 AM
sumncguy's Avatar
sumncguy
Default RE: Towing
http://www-5.dodge.com/towing5/D/home.html
http://www.trailerlife.com/
Old Apr 17, 2007 | 02:42 PM
sumncguy's Avatar
sumncguy
Default RE: Towing
http://www.geocities.com/vidalch_1/t...monstrator.xls
A spreadsheet towing demonstrator.
Old Jan 25, 2008 | 01:23 PM
Gwub2005's Avatar
Gwub2005
Default RE: Towing
Check ur hitch rating it will be on the hitch most mini vans have a rating of between 1500 and 2500 lbs. U will only need a tranny cooler if u will be towing alot and if u will be towing in hilly situations.
