Spark Plugs
Old May 22, 2007 | 01:14 AM
crankcase1943's Avatar
crankcase1943
Default Spark Plugs
I am now the proud owner of a 95 Grand Caravan. 156K miles. Runs pretty good. I would like to replace the spark plugs. I am a retired auto tech about 10 years ago so I still do my work. The engine is a 3.3. What is the easiest way to get to the back 3 plugs? I was thinking of pulling the intake plenum. Is this the way? Also when I hit a good size bump the front springs seem to bottom out. The front shocks look real clean as if they are not too old. Does the van have weak springs or does it supposed to have gas shocks or something like this? I am getting between 18 and 19.8 miles to the gallon, is this about right?
Old May 22, 2007 | 11:16 PM
next2pool's Avatar
next2pool
Default RE: Spark Plugs
There are several different opinions on how to change plugs on 3.3 and 3.8's. I replaced #3 and #5 from behind laying on the ground with numerous flex and swivel connections--not fun! I flipped back the alternator and got to #1 quite easily. Since that time, I had to remove the plenum to replace the gasket and in the future, that's what I will do to change the rears!
Old May 23, 2007 | 12:13 AM
crankcase1943
next2pool
Thanks for the info about changing the plugs. thats the way it looks to me.
Old May 23, 2007 | 01:39 AM
master tech's Avatar
master tech
Site Moderator & Tech
1995 van is the old AS body, 1996 started the NS body, the best way to replace the rear spark plugs is to replace all three from the bottom. The only need to remove the short P/S backet, two 15mm nut and bolt.
Old May 26, 2007 | 08:50 PM
crankcase1943
I just got through changing the plugs. I pulled the intake plenmum back and got to the back three. Not to bad.
