2-1 rough downshift, fault code P1775...
#21
#22
P1775 is a TCC in latch position, Replace the valve body and filter too. There also a P1776 for low reverse stuck in latch position too. Remove the pan ck for metal. no metal replace the valve body. or if you like the diagnostic sheet for your codes , just e-mail me and I'll send it to you.
#23
Same issue
Is there any way you could help me with this p1775 code. I have it on a 1997 dodge ram 1500 4x4
