Air bag Dash light
Old Sep 25, 2007 | 09:49 AM
fhb_01's Avatar
fhb_01
Default Air bag Dash light
I have a 2002 Caravan and the air bag dash light keeps coming on and off. It only comes on when I am driving and making a turn (Right or Left) then when I drive straight the light goes back off. If I am sitting in the driveway and not moving I can turn the steering wheel and the light stays off. Does anyone know anything about this???????
Old Sep 25, 2007 | 04:01 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: Air bag Dash light
get the code scanned for the air bag computer and go from there.
Old Oct 28, 2007 | 06:02 PM
pgcorky's Avatar
pgcorky
Can you use a regular code reader for this job? I've had a similar problem with intermittent Air Bag light illuminating, but when I do a code read I get "no codes found". Of course I'm reading for a code when the light has managed to go off again....
Old Oct 28, 2007 | 06:41 PM
Dodge Tech's Avatar
Dodge Tech
no u need a high end scanner or a chrysler DRB both are around 5k each so u would be better off going to a dealer or a shop that can read the air bag computer.
Old Oct 29, 2007 | 10:17 AM
pgcorky's Avatar
pgcorky
Whoa! I looked at the DRB III scanners - that's a lot of cash - so I'll leave code reading to the dealer I guess. But based on some other research, it sounds like an intermittent airbag warning lightmight have to do with a weight sensor on the passenger seat. Does that sound possible? I know guessing is no substitute for a real diagnosis, but I've seen some other forums indicating that Dodge put in a system that senses weight in the passenger seat so that it wouldn't deploy if a child (or anyone less than about 40 lbs ) was in that seat. So I'm wondering if I can try to recalibrate that or if that's a dealer only kind of adjustment... Just a thought. I know that when I drive the van by myself the light doesn't seem to go on, but when my wife is with me, it's off an on. FHB-01, do you get the light if you have a passenger or 50 lbs of bricks on the seat!?
Old Oct 29, 2007 | 07:36 PM
floorslayer1's Avatar
floorslayer1
Chances are your clockspring is going bad. Check with your dealer about recall.
Old Oct 29, 2007 | 08:43 PM
pgcorky's Avatar
pgcorky
Anybody know if 2003 was covered in a clockspring recall? I saw a lot about 1998 through 2000 model years, but nothing beyond. I guess it could be the clockspring even without a recall which would just be my luck. So has anyone done a good write up of the procedure to replace? Can a guy with average tools and know how get this done.
Old Oct 31, 2007 | 12:04 AM
master tech's Avatar
master tech
Site Moderator & Tech
There are no recalls on clockspring on 2003.
Old Nov 7, 2007 | 12:20 PM
pgcorky's Avatar
pgcorky
Well, just got a call from my mechanic. He says I need a new driver side airbag and that will be $800 please. Of course the person on the phone can't tell me why an undeployed airbag in a 4 year old car would be faulty. Don't understand it. I may take it to another shop for a second opinion - but certainly would like to hear what you all think! Thanks!
