Air bag light came up on the dashbord
Old Dec 13, 2007 | 10:52 PM
fve454's Avatar
fve454
Default Air bag light came up on the dashbord
Hello to all, I hope someone can give me an idea on how to fix my problem , the light of the AIR BAg came up for no reason on the dashboard , I already disconnected the negative side of the battery, thinking that if the computer reset it will go away , but did not work .. any help or hint will be good .. Thanks
Old Dec 13, 2007 | 11:05 PM
fve454's Avatar
fve454
Default RE: 2000 Caravan Air bag light came up on the dashbord
Hello to all, I forgot put mention that I have a 2000 Dodge Caravan, the light of the AIR BAg came up for no reason on the dashboard , I already disconnected the negative side of the battery, thinking that if the computer reset it will go away , but did not work .. any help or hint .. Thanks
Old Dec 14, 2007 | 12:48 AM
imamacanac's Avatar
imamacanac
Default RE: Air bag light came up on the dashbord
Not sure if this will help but, I had a 95 Caravan and the rear wiper motor seized up. The fuse blew and my airbag light came on checked all the usual things and no luck. Found out that the airbag and rear wiper are on the same fuse. Changed the fuse and presto the airbag light went off.
Old Dec 14, 2007 | 10:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
Your van may have the lifetime recall for the clockspring, D17 Or B24.
Old Dec 15, 2007 | 12:12 AM
fve454's Avatar
fve454
Thanks to all , Master can u tell me what is D17 Or B24
Old Dec 15, 2007 | 12:20 AM
fve454's Avatar
fve454
II forgot to mention that after checking all fuses and also taking the neg side of the battery and turning the ignition on for 15 second . I also noticed that the horn and cruse controls are not working .. any sugestions .. thanks
Old Dec 16, 2007 | 03:48 AM
dishdude2k's Avatar
dishdude2k
sounds to me like you need to check fuses.. and check connections in the power box in the engine compartment
Old Dec 17, 2007 | 01:42 PM
floorslayer1's Avatar
floorslayer1
Airbag , Horn , Cruise......Its the clockspring ......
Old Dec 20, 2007 | 12:04 PM
fve454's Avatar
fve454
A BIG THANKS to all. The Dodge dealer fixed the problem. I was the clockspring (D17) and yes, it is a recall that is still unfinish on these cars.
Again Thanks for your help
