2001 Caravan Sport transmission problems
Wife put hole in transmission pan. I am sure she tried to move it without enough fluid. Replaced the pan and filter, put in 4 qts. When put in forward or reverse it has tohave high rpms to engage and the transmission fluid is foamy. Any suggestions thanks
I don't know specifically for the 41TE (the tranny in your van), but many will slowly drain a lot more fluid than what is in the pan if you just leave them sitting with the pan open (or in this case with a hole in it), so don't assume that it only needs 4 qts. Fill, check, fill, check, etc until the level is correct.
