MIL Code 54:No Cam Signal at PCM
on
RE: MIL Code 54:No Cam Signal at PCM
1st of does the engine start and run? There could be many reason why the tach reads zero. You need to ck with a dvom if you have a 8 volt at cav #3 and ground #2 and cam signal # 1. You could have an open wire or short, or even a bad pcm. To diag this problem you will need a DRB3 scan tool.
It happens intermittently and more often now. When the tachometer shows zero, the engine stalls or sometimes the tachometer recovers with a jolt of the car. After the stall, the engine can be restarted. I took out the camshaft position sensor. It looked fine. I cleaned it and put it back. I feel the engine is stronger, but the stall still happens. I hope it's not the PCM problem. Any suggestion will be greatly appreciated.
I have compared the old cam sensor with a new one using a scope and found the rising edge is different. The old sensor's rising edge (output signal from 0v to high) is much longer than the new one.Forgot how much exactly. I changed the sensor and the van looks fine now.
