help??master tech??
Old Jan 20, 2008 | 03:45 PM
goofydaddy12000's Avatar
goofydaddy12000
Default help??master tech??
i need help my 96 caravan is in limp mode i did a ignition code check and got code 12,32,55 i know what the 12,55 are for and the 32 is for egr system failure would that be what put my van in limp mode.please help i am going to take it to the shop this week but it would help if i knew what the prob might be. thanks
Old Jan 20, 2008 | 11:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: help??master tech??
When you turn the key on/off three times you will only read the stored codes in the PCM. For all of the other modules you will need a scanner. No an EGR code will not put the transmission into limp-in. Ck your speedometer when moving the van,if it doesn't move its a good chance the output sensor has a problem. sensor or an open wire. But you will need to remove the codes out of the TCM. Leonard
