Speed/Speedometer sensor??
Old Jan 22, 2008 | 03:17 AM
jasann's Avatar
jasann
Default Speed/Speedometer sensor??
I have a 2001 grnd caravan (3.3 w/4spd auto)and the speedo does not work, itried a new instument cluster(used) but it did not work. i tested the cluster in another van and itand original work ok. someone suggested the speed/speedometer sensor on the trans but where is it located and is it easy to remove? thanks for any help. joe
Old Jan 22, 2008 | 12:11 PM
onephatcracka's Avatar
onephatcracka
Default RE: Speed/Speedometer sensor??
there is an input and output. Both are on the front of the trans above the solenoid pack.
Old Jan 23, 2008 | 12:11 AM
master tech's Avatar
master tech
Site Moderator & Tech
The input turbine sensor is closes to the torque converter or bell housing and the output is near the end of the transmission. You will need a 1 inch socket.
