Radio/Clock Not Working in 2001 Dodge Grand Caravan
Old 02-25-2008, 08:28 AM
jenlaw77's Avatar
jenlaw77
jenlaw77 is offline
Default Radio/Clock Not Working in 2001 Dodge Grand Caravan
Hi-
The radio/clock stopped working in my Dodge Grand Caravan. My husband checked the fuses, and couldn't find one that needed to be replaced. Everything else works fine...does anyone have any idea what the problem could be?
Side note--this occurred after we jump-started the van. There's some "module" under the van that needs replacing. This damaged module causes the displays to remain "on" even though power to van is off. So, every few days we have to jumpstart the van to correct the power drain. I don't think this is related to the radio/clock issue, but I guess it could be.
Old 02-25-2008, 11:26 PM
dishdude2k's Avatar
dishdude2k
dishdude2k is offline
Default RE: Radio/Clock Not Working in 2001 Dodge Grand Caravan
its actually more common than you think.. any time you jump start a vehicle.. anything can happen.. especially to the radio.. you wouldnt imagine how many i have seen go in just this way.. more than likely the radio will need replaced.. as will that module.. when you jump it .. it can surge the system.. more common on fords.. but not uncommon on anything else.. fix that module then replace the radio
Quick Reply: Radio/Clock Not Working in 2001 Dodge Grand Caravan
