2001 Caravan SE stud r/r
Old Mar 17, 2008 | 10:51 PM
KenoshaWarrior's Avatar
KenoshaWarrior
Default 2001 Caravan SE stud r/r
Ive been assigned the wonderful task of doing the drivers side studs on my father's '01 Caravan SE 3.8L
I need a bit of info. First, what do I do after removing the caliper? AFAIK caravans use a unit bearing/hub setup, correct? I'm familiar with Jeeps (XJ's to FSJ's to *****'s wags and such) and haven't so much as touched anything mechanical on this van.
The studs I know how to r/r, but getting everything apart is what info I lack. My dad seems to believe its a multi-part setup on a spindle but Im lead to believe that its a unit bearing setup. Anyone care to set us both straight?
Old Mar 17, 2008 | 10:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 2001 Caravan SE stud r/r
Are you doing just one stud or all five?
Old Mar 17, 2008 | 11:20 PM
KenoshaWarrior
All 5, one is already toast and another has a seized lugnut so all 5 are coming out.
Old Mar 17, 2008 | 11:35 PM
master tech
Then I would replace the hub assy. and yes its just like the jeeps.
Old Mar 17, 2008 | 11:59 PM
KenoshaWarrior
money constraints at this point in time, so just the studs will have to be done, thanks for the info though.
Old Mar 18, 2008 | 12:07 AM
master tech
You can still do just the studs with the hub on the van. You just need a hammer to knock the studs out. then use the lug nut to pull the studs though the holes. you will need a either a stud installer or a bigger nut to pull the stud though, along with the lug nut.
