2004 Caravan Sxt anti freeze leak
Old Mar 24, 2008 | 08:17 PM
samtheman's Avatar
samtheman
Default 2004 Caravan Sxt anti freeze leak
I am having a tough time locating an coolant leak, it appears to be somewhere around the water pump but can not say definitely, sometimes it leaks, sometimes it doesn't. I was wondering if the water pump on this vehicle has a weep hole and maybe it is leaking from there. If so, What would cause coolant to leak from the weep hole and what is the remedy?
Thanks for you help.....Sam
Old Mar 25, 2008 | 09:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 2004 Caravan Sxt anti freeze leak
That problem could be the water pump. Raise the van and remove the rubber plug that on the water pump. Dodge had put a plug on their water pumpsaround 1996. The plug was stop any seepage from hitting the ground.
