Dodge Ram Van power window problem
Old Apr 11, 2008 | 05:56 PM
donsaut's Avatar
donsaut
Default Dodge Ram Van power window problem
New user here. Hope I'm following correct procedure....
On my 98 dodge ram van the passenger side power window won't go up or down. I removed door cover and can see a loose cable that moves when power is applied so I'm assuming a broken piece that the cable travels on? I hesitate to remove more of the power window guts until I know more info. Would appreciate a wiring diagram of moving parts if possible. If can help it would be most appreciated!
Don In Indiana
Old Apr 11, 2008 | 07:46 PM
HemiMan02's Avatar
HemiMan02
Default RE: Dodge Ram Van power window problem
if it is a black plastic cable (covers the steel cable) that is flopping around then it needs a window regulator. You can test the wiring to the motor very easily. Disconnect the plug and hook in a high beam headlight if it lights up when you flip the switch you have plenty of juice.
