Kickdown and throttle
Old Apr 19, 2008 | 08:22 AM
alwaysdutch's Avatar
alwaysdutch
Default Kickdown and throttle
What is the best metod to make adjustments onthe throttle valve for a new transmission. I have the '96 3.0 driving butI have to give too much throttlebefore i shifts and it wants to kick down too early.
I have a throttle arm that connects the valve throttle with the transmission throttle lever.
Old Apr 23, 2008 | 11:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Kickdown and throttle
Have someone push the throttle down to the floor and then loosen the 1/2 or 13 mm bolt and make your adjustments. This is abase way of an adjustment. Then make the final adjustment on a road test.
