A/C Problem 98 Caravan
Old Jun 8, 2008 | 12:35 PM
alydar66's Avatar
alydar66
Default A/C Problem 98 Caravan
Hi, I have a 1998 Caravan that failed the cool-down test so I decided to recharge the system. I had the engine running and the a/c on when I started to fill system. About 15 seconds after I opened the valve to let the refridgerant in the system there was a loud pop. I turned off the engine and closed the valve on the refridgerant. I looked at the hoses and I now have a big hole in the other hose that comes off the compressor. Did I do something wrong or do these hoses fail sometimes and I just need to replace the hose? Thanks.
Old Jun 9, 2008 | 10:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: A/C Problem 98 Caravan
You may have put to much freon in the system or the hose was ready to go anyway.
Old Jun 9, 2008 | 11:42 PM
alydar66's Avatar
alydar66
I dont think I put to much in because the system was empty and I think less than a half a can went in before the line burst.
Old Jun 10, 2008 | 09:17 PM
kchopper's Avatar
kchopper
The hose was probably weak. Even if there was high pressure, the high pressure relief valve on the compressor should of opened up before the hose would blow.
