99 Voyager 3.3 Transmission Interchange?
Old Jul 2, 2008 | 02:30 PM
doman's Avatar
doman
Default 99 Voyager 3.3 Transmission Interchange?
hello All
Can anyone tell me what other years will interchange with my 99 voyager ...i cant find any 99 at the moment but i did find a 2000 caravan and 97 caravan with the same engine im just not sure whihc one of these is a better choice..
will 00 interchange directly or do i need to swap parts around? ...any help would be really appreciated
thanks
dom
Old Jul 2, 2008 | 06:47 PM
deezozdodge's Avatar
deezozdodge
Default RE: 99 Voyager 3.3 Transmission Interchange?
Perhaps talking to a dealer service advisor?
Old Jul 2, 2008 | 08:29 PM
doman's Avatar
doman
They go by the vin # and get a part number and thats it as far as interchange they are unable to tell me ....Called few junk yards some say 96-02 will work just fine some say 99 only and others 99-02 ..so at this point im looking for an answer from someone who has worked on one of these trannies and actually done a swap or knows if in fact which ones interchange and which do not or what needs to be changed out in order to use a newer or an older tranny...
thanks
dom
Old Jul 2, 2008 | 09:21 PM
floorslayer1's Avatar
floorslayer1
96-2000 will all work with the possibility of a couple of electrical plug differences. At which point if there are any differences, simply switch electrical component (sensors most likely) with the old one or a new sensor of the correct year and you'll be fine.
Old Jul 3, 2008 | 11:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
1997 thru 2002 will work, but you need to look at the TRS sensor ( transmission range sensor ) the early 41te trans have round pin connector and the newer trans has flat pins. So you need to get a jumper harness, Also one last detail match the torque converter to the flex before installing the transmission. Because you may need an updated flex plate too. If you need part numbers just send a pm.
