How many o2 sensors?
Old Aug 11, 2008 | 08:59 PM
aij3's Avatar
aij3
Junior Member
Default How many o2 sensors?
How many o2 sensors are there on a 2003 Grand Caravan Sport? 3.3l engine.
Where is the bank 1 sensor 1 o2 sensor referenced by code p0135 located? Is it that one to the rear of the engine (rear exhaust manifold, really hard to get too it seems) ?
I see two of them. The one I mentioned above and the one on the side of the catalytic converter. I thought I read a post somewhere saying that this vehicle has 3 02 sensors?
Please correct me if I'm wrong but this is how I understand it:
bank 1 sensor 1 is the 02 sensor on the rear manifold?
bank 2 sensor refers to the sensor on the side of the catalytic converter?
where is the other one if there are 3 of them?
Could anyone provide photos or diagrams showing where they are?
I have the haynes manual but it only references an upstream and downstream sensors.
Thanks.
Old Aug 11, 2008 | 09:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
There is two. one upsteam and one downsteam.
Old Aug 12, 2008 | 07:32 PM
aij3's Avatar
aij3
Junior Member
Hi Master Tech,
Thanks for the reply. Just a quick question on the tool I need. Is there a particular size o2 sensor socket for this particular o2/vehicle?
Could click on the link below and tell me if this would work?
http://www.canadiantire.ca/browse/pr...=1218583623815
Thanks again.
Old Aug 12, 2008 | 08:17 PM
master tech
You can cut off the wire at the o2 sensor and use a 7/8 deep socket or box end wrench. Or a o2 sensor socket tool. Also 7/8 is the same as 22mm.
