98 caravan 3.3 missfires
Old Aug 19, 2008 | 09:58 PM
CanuckBC's Avatar
CanuckBC
Cool 98 caravan 3.3 missfires
was driveing along one day and the check engine light comes on do a ignition code check says code 43 Cylinder missfire not enough info so get a code reader and it tells me no# 5 cylinder is the bad one so i do the easy stuff first ...plug /plug wire /had a spare coil change that nothing did injector cleaner twice still no good so i did the injector still running bad so i was feeling the plugs at the injectors and noticed there was no ticking at the number 5 injector thinking it was a bad connection i replaced the harness lead to the injector still no go now in stumped and answers to my issue ?
Old Aug 20, 2008 | 11:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Do a compression test on the cylinder. You could have a flat cam or a broken rocker tower.
Old Aug 21, 2008 | 12:10 PM
CanuckBC's Avatar
CanuckBC
compression test says on all front cylinders’ is 90 to 95 on first stroke 110 to 120 second stroke and 130 psi on 3rd on all cylinder’s with the issue cylinder being the strongest of all
Old Aug 21, 2008 | 06:14 PM
CanuckBC's Avatar
CanuckBC
also removed valve cover and all is ok every thing going up and down
Old Aug 28, 2008 | 11:06 AM
CanuckBC's Avatar
CanuckBC
went to dealor told them my issue and was told that computer might be faulty So what would happen if i went to wreckers and swapped computers with same year model etc
