04 Grand Caravan Sxt Heater/ A/c Problem
Old Jan 10, 2009 | 07:14 AM
shastylz's Avatar
shastylz
Well it was the resistor after all.. thanks for everybodys help on this
Old Jan 10, 2009 | 11:48 AM
RicksTrucks's Avatar
RicksTrucks
Default same problem
I have a 2004 with the same problem. What exactly did you replace - where is it located.
I checked mine and there is power always coming from one of the two terminals, when the ignition is on, that the fan plugs into. When I plug the fan plug in, then there is power to both connectors, whether the fan is turned on or not.
Old Jan 11, 2009 | 06:23 AM
shastylz's Avatar
shastylz
Yeah it will still have juice to it but its telling the motor not to spin so i replaced the resistor. It is located behind the glove box with the two terminals that you just tested to see if there was juice unplug those terminals and then there are two 5/16 screw on each side of that resistor once you take out the screws it just comes right out and thats the resistor. once you get the new just put it back into where the old came out of plugs in the terminals and put your glove box back and if it is the same exact problem you will have air coming from the vents.. Just F.Y.I i paid $23.62 after tax for the resistor its a Dealer Item only
