02 Grand Caravan Compressor Noise??
From time to time I get a loud rattling noise that speeds and and slows down with the engine speed. To get it to stop, I have to pull over, shut off the engine, and try starting again till it stops. The sound seems to be coming from the air conditioning compressor. It doesn't seem to matter if I have the heating/cooling system on or not. Could it be the clutch making the sound since I recall reading at one time that it can happen.
Thanks in advance.
Thanks in advance.
The compressor and clutch shouldn't be engaged with the heater system turned off.
The bearing on the Compressor clutch pulley rotates any time the engine is running so it's possible this is your noise but it not common for the noise to come and go. Bearings usually make a rumbling growling noise that is constant but will change pitch with engine RPM.
See if you can narrow down the noise with a stethoscope, rubber hose, or pry bar pressed to your ear when the noise occurs. Generally the loudest component is the faulty one.
