pcm
Old May 5, 2009 | 10:30 PM
rhino24's Avatar
rhino24
Default pcm
i have a 2002 dodge caravan codes say that a/c compressor,ect,inj4,tps is all bad i think that the pcm is shorted any thoughts?
Old May 5, 2009 | 10:45 PM
utkan's Avatar
utkan
Have you tried to reset the pcm (clear the codes) and see what will you get after that.
Old May 5, 2009 | 10:51 PM
utkan's Avatar
utkan
Check this Thread out https://dodgeforum.com/forum/dodge-c...o-i-start.html. Sounds like same problem.
Old May 6, 2009 | 06:46 PM
rhino24's Avatar
rhino24
yeah i did that and all the codes didnt come back but it is still misfire i am going to starrt checking the pins on the pcm i dont know what else to do cause the prblems arre so out there
Old May 6, 2009 | 07:34 PM
utkan's Avatar
utkan
You might wanna check the injector to see if it is shorted using voltmater.
Old May 6, 2009 | 11:05 PM
rhino24's Avatar
rhino24
woluld that also cause other problem i never seen that before. i check wire and seems to be firing alright but one of the codes says its missfiring
