tuneup
Old May 11, 2009 | 07:54 PM
dodge250's Avatar
dodge250
Default tuneup
I have dodge caravan 2000 want to do some tunep. witch parts envolve in tunep? and should i chang trans oil. 140402km never did tunep yet.
thanks in advance
Old May 13, 2009 | 12:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
Spark plugs, Wire set, Fuel filter,Air filter,PCV valve and Throttle body clean. And remove the AIS motor and clean too.
Old May 13, 2009 | 04:23 PM
surfit's Avatar
surfit
What's an AIS Motor? How do you clean it - inside?
Old May 13, 2009 | 09:41 PM
master tech
Automatic Idle Speed motor. Its bolted next to the TPS( Throttle Position Sensor).
Old May 15, 2009 | 08:38 PM
tscaravan's Avatar
tscaravan
If it's a 3.3 or 3.8 you'll have fun getting at the rear spark plugs!
Old May 18, 2009 | 11:15 AM
surfit's Avatar
surfit
It's a good thing I have small hands, I can get to two of the rear
plugs easily. One, I must remove the alt. Also, with platinum tipped
spark plugs, I'm not even checking the plug gaps - just change at
100K miles.
