02 aravan Power Window Problem
Old Jun 2, 2009 | 05:22 PM
roswellbootie's Avatar
roswellbootie
Default 02 aravan Power Window Problem
I have an '02 Caravan and the Driverside power window came off its track - I took the door panel off and got the pins back in the holes on the guides that slide up and down. The window comes down normally but it is slow and bogs, down and stops about 4 inches from the top. Anybody out thier with any ideas?
Old Jun 2, 2009 | 11:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
You maybe between the window channel and door. You'll need to remove the window and clean the channel.
Old Jun 3, 2009 | 08:01 PM
tngolfnut's Avatar
tngolfnut
I have a 2002 grand caravan. Had to replace the drivers side window regulator and motor. I think I got it at either at advance or autozone. Would go down go, then either slow going up or just stop going up. Banged on the motor and it would start again for a while. Then just decided to replace the whole thing.
