Where to buy power latch?
Old Aug 20, 2009 | 12:13 AM
CumminsRam's Avatar
CumminsRam
Default Where to buy power latch?
looking to fix my power liftgate issue and just trying to find out where I can get this part for cheaper than stealer of $175+tax
this is not the power motor for the liftgate but the power liftgate LATCH.
Thanks for your help
Old Aug 21, 2009 | 12:12 AM
rabbler's Avatar
rabbler
Are you positive its the latch?
The release switch on the tailgate is very common to fail and cause it to not open.
Old Aug 21, 2009 | 12:45 AM
CumminsRam's Avatar
CumminsRam
well from what I've been reading, symptoms are the same so I'm assuming it's the latch.
when I press it manually at the rear, the latch is unresponsive to the handle so I would have to use the key.
Any Online vendors that sell parts for cheap?
Old Aug 21, 2009 | 09:01 PM
rabbler's Avatar
rabbler
I've replaced probably close to a hundred liftgate switches. Don't recall ever replacing a latch that wasn't collision damage.
Switch is cheaper if you're guessing...
Old Aug 23, 2009 | 11:33 PM
CumminsRam's Avatar
CumminsRam
so where can i get the switch from?
Old Aug 24, 2009 | 12:33 AM
rabbler's Avatar
rabbler
Dealer only.
or junk yard
Old Aug 24, 2009 | 03:31 PM
CumminsRam's Avatar
CumminsRam
well, what I meant is... usually there's a dealership or two that sponsors the forum for discounts. I've belonged to many that had exclusive forum discount. I am surprised to see there aren't any dealers here that is willing to discount the parts
Old Aug 24, 2009 | 05:42 PM
CumminsRam's Avatar
CumminsRam
also, if I don't clear the codes, will replacing the latch not work?
Old Aug 24, 2009 | 08:02 PM
rabbler's Avatar
rabbler
Disconnecting battery should clear codes.
What codes are you getting?
You should have mentioned them earlier.
Old Aug 26, 2009 | 03:36 PM
CumminsRam's Avatar
CumminsRam
i don't know whether I have a code or not but some said there will be codes if the liftgate fails to open.
so there is NO one to purchase parts from online at a discount????
