HELP Please...tranny
Old Oct 4, 2009 | 09:30 PM
shelbydaytona's Avatar
shelbydaytona
and if the shop opens the hood to connect the scanner, run away they have no flippin clue wtf the are doing. the connector is under the dash or in the fuse block and is bright blue.
Old Oct 4, 2009 | 09:33 PM
drummer1279's Avatar
drummer1279
hehe will do. thanks for all the advice and I will keep you guys posted
Old Oct 4, 2009 | 09:42 PM
shelbydaytona
have you been able to find the connector yourself?
Old Oct 5, 2009 | 03:23 PM
drummer1279
yea I located it. and even the mechanics at the Dodge dealerships look at me stupid when I tell them not the underhood the one inside.
Old Oct 5, 2009 | 03:24 PM
drummer1279
so im going to start with the most logical piece that could be causing it and replace the shift solenoid
Old Oct 5, 2009 | 03:53 PM
shelbydaytona
why? maybe you should also toss in some speed sensors, shift position switches and a tcm and tcm relay, then you got all the electrical stuff covered. if it still dont work maybe go on the internet and find yourself a real scanner. i sold my drbii scanner on ebay a few years ago for $200 i used the money twards a snapon solus because the drb2 only went to 1995 and wasnt obd2 plus i work on other stuff besides chrysler
Old Oct 5, 2009 | 04:06 PM
drummer1279
hey theres no need to be a smart alec about this. and you know not everyone has a pile of money lying around to just buy a scanner tool. I picked up a used shift solenoid for $60 with the option to return if it didnt fix the problem.
Old Oct 5, 2009 | 04:07 PM
shelbydaytona
Old Oct 5, 2009 | 10:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
Hi drummer1279
Did you get my PM to you? The reason the dealer techs look at you so stupid and a lot of other techs will too, is because one they don't look up TSB's or not old enought to have worked on the early mini vans.
Old Oct 6, 2009 | 06:37 AM
shelbydaytona
actually there is im trying to make a point, you can throw parts at it all day and have more $ stuck into it than it would have cost to buy a good used scanner, get it diagnosed correctly the first time and saved alot of screwing around. besides once you have a scanner dont u thing ud use it again and again and again? do you own a big screen tv? if so why? get my point? did you get new gaskets for the solenoid pack? that's another expense you'll need to spend. besides im fairly certain this isn't your problem. but if it does fix it more power to you.
