Different left turn signal prob
Old Nov 16, 2009 | 09:18 AM
rcs12185's Avatar
rcs12185
Default Different left turn signal prob
Our 2000 Grand Caravan FWD has a moody left turn signal. Most of the time it does not work, but maybe at the next stop light, it may work and so on. Right side is fine. Cruise and hazards work normal, no airbag light or anything. Should I try a different switch or do you think maybe a "clock spring"? A lot of good help on the diesel forum, hopefully someone here can bail me out.
Old Aug 6, 2010 | 12:58 PM
rezonator's Avatar
rezonator
i have the exact same problem, tried a new switch assembly with no luck.
right side works normal and left only works once in a while
can anbody help
Old Aug 6, 2010 | 12:59 PM
rezonator's Avatar
rezonator
btw i have a 96 caravan, i think they are the same?
Old Aug 6, 2010 | 01:27 PM
Tizzy1's Avatar
Tizzy1
probably the flasher. If you look down by the brake pedal there is a fuse box. Above the row of fuses there is a row of relays. One relay is much taller than the rest. that is the flasher. Try and hit it when the signal won't flash and see if they start working.
Old Aug 7, 2010 | 10:17 AM
Hymyldsl's Avatar
Hymyldsl
We fixed the problem.. It was actually a bad lens assembly. The contacts to ground the assembly were worn and not making good contacts. Put a used one in and now no problems.
Old Aug 7, 2010 | 02:53 PM
rezonator's Avatar
rezonator
was that the rear lens?\
which contacts are you talking about, the ones right on the bulbs?
Old Aug 9, 2010 | 11:13 AM
Hymyldsl's Avatar
Hymyldsl
Might sound dumb but it has been a while since we had this, I remember ordering a whole tail light assemby,(housing only) from the junkyard and put it in. I think sometimes it worked when we would slap the tail light, that is why I changed it. I think it was only $20.
Old Aug 9, 2010 | 01:51 PM
rezonator's Avatar
rezonator
well i hit the flasher and problem is gone!
so next time this happens i will just replace the flasher
Thanks for all the replys
Old Aug 9, 2010 | 03:36 PM
Tizzy1's Avatar
Tizzy1
wow! I was right for once, yay me.
Old Aug 10, 2010 | 06:47 AM
Hymyldsl's Avatar
Hymyldsl
AH HA. Well guess what, my diesel truck didn't have all 4 turn signals for 2 years and after trying everything the guy at the shop asked me if I tried the flasher. That's all it was for my truck, but the van on the other hand still required the tail light assembly. Glad you got it fixed, small price to avoid getting rear ended.
