2006 caravan left signal problem
Old Dec 11, 2009 | 09:51 PM
pmclaren's Avatar
pmclaren
Default 2006 caravan left signal problem
I have a 2006 dodge caravan sxt which has developed a left signal problem. The signal light works fine most of the time but stops working some time. When in acts up you can put the left signal on and nonthing. but sometime the right indicator will flash for a short time. Is it in the switch?
Old Dec 15, 2009 | 11:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
The dealer may be fix this problem, if you are still under warranty. It may be just a flash for the FCM. I have notice on the PT and 1500 trucks with lighting problems a flash would fix it.
