(Transmission Solenoid) -- Is It Leaking? Where Is it?
When you replace a solinoid pack, you need to make sure the area around it is clean before you pull it off or dirt falls into the valve body / transmission pan. When I do a solinoid pack, I always do a transmission service also to make sure it is as free from dirt as possible. Nothing special is needed to be done when replacing the cooler lines and it is usually a loose clamp that causes them to leak.
In my case, the leak was loose hose connections with the radiator. Once I tightened them down, I had no leak. I replaced one clamp because as I was tightening it, I could tell that it was slipping teeth. If you replace the hoses (I didnt), I would use vice grips to clamp the hoses shut (gently) as you make the hose replacement. You wont lose much fluid that way. Of course, do this when the engine/tranny has cooled. I have not replaced the solenoid pack, so I cannot comment on that.
