96 caravan pops when accellerating
Old Dec 19, 2009 | 09:52 AM
jackb's Avatar
jackb
Default 96 caravan pops when accellerating
hi everyone, my 96 caravan v6 pops when i accelerate, like back in the carberater days. if i give it a little it is not as bad, please help. thanks jackb
Old Dec 19, 2009 | 12:28 PM
jackb's Avatar
jackb
Default spitting back???
il try to describe it better, like it is spitting back,??????
Old Dec 19, 2009 | 01:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a misfire and that will cause a backfire thru the throttle body. Replace the spark plugs and wire set, if you are having a misfire problem. Also clean the throttle body too.
Old Dec 20, 2009 | 07:10 AM
circumventor's Avatar
circumventor
and chekfuel presure cuz if the moter goes lean thats wen intak backfire hapens and low fuel prss does this and so does a vaccuum leak
Old Dec 20, 2009 | 01:15 PM
92dak5.24x4's Avatar
92dak5.24x4
This can commonly be attributed to a cracked flex plate. I doubt you have the best tools to diagnose which would be an oscilliscope.
