Squeal when cold
Old Dec 28, 2009 | 02:41 PM
travisg96's Avatar
travisg96
Default Squeal when cold
I just purchased a 2007 Grand Caravan SXT. When it is cold there is a squeal that sounds like the powersteering being oversteered but it is there all the time. after it warms up the noise goes away untill you come back and start it up when it is cold. Is this normal, has anyone else had a problem like this? Dealer want's $60 to look at it and diagnose the problem.
Travis
Old Dec 28, 2009 | 07:04 PM
92dak5.24x4's Avatar
92dak5.24x4
any squeeling is NOT normal. So instead of going to a dealer, isn't there any other reputable repair facilities.
Old Dec 28, 2009 | 08:37 PM
RickMN's Avatar
RickMN
Depends how you define squeal. Most common cause is plugged filter in P.S. fluid reservoir. Once the P.S. fluid heats up, it softens the crud and swirls it around. Then it settles and hardens when it gets cold again.
Here's a post with photo:
http://www.ricksfreeautorepairadvice...ysler-vehicles
Old Dec 28, 2009 | 10:16 PM
Ram_It98's Avatar
Ram_It98
check your belts
Old Dec 29, 2009 | 01:51 PM
travisg96's Avatar
travisg96
I will check the belt and filter in the resivoir. It definatly is associated with the power steering since the noise get's worse when you turn and goes away when it warms up.
Travis
Old Jan 23, 2010 | 10:57 AM
YuNVme's Avatar
YuNVme
I would suspect Old Belts as well...
Old Jan 23, 2010 | 11:08 AM
Tizzy1's Avatar
Tizzy1
I expect low fluid or a plugged screen, see it all the time.
Old Jan 24, 2010 | 08:18 PM
Repo's Avatar
Repo
Check your belts!
Old Jan 25, 2010 | 05:58 PM
travisg96's Avatar
travisg96
I vacumed out the old fluid and replaced it with new fluid and the noise went away.
