I messed up my heater...HELP PLS
Old Jan 1, 2010 | 03:40 PM
Bluestreak95's Avatar
Bluestreak95
Default I messed up my heater...HELP PLS
hello all i have a 96 caravan today i went outside to see if the cables behind my heater/AC control panel were burnt because my wipers were also not working. My heater was working b 4 i did this FYI. i pulled the pannel off n unplugged the wire. then i plugged them back n and nothing....my radio,rear defrost and vent positions all work but i have no blower....what could have happend!! is there more than just one fuze under the hood for the blower?
Old Jan 1, 2010 | 04:49 PM
92dak5.24x4's Avatar
92dak5.24x4
fuse under the dash, I love the 'ever since i fixed my car, now its broke' story. I don't understand why you'd pull apart the heater controls for the wipers (plural) not working or are you talking about the rear WIPER (singular). Take off the heater control panel and recheck and see WTF you might have left off or not connected correctly or damaged. and see if you have power to the blower switch, then you can eliminate the fuse. A wiring schematic would be of great value to answer all your problems.
Old Jan 1, 2010 | 04:57 PM
Bluestreak95
the only fuze i could find for the blower was under the hood it was the 40 amp fuze...other than that i could not find any other fuzes. i also have power to the switch i put a ohms meter to the switch and also to the wire harness and i do get power from both the switch and harness...i hate these model and year of caravans...
Old Jan 1, 2010 | 05:00 PM
Bluestreak95
is there any way i can test my blower motor?
Old Jan 1, 2010 | 05:14 PM
92dak5.24x4
yes, it's called a test light or a multimeter or maybe you can come up with some other method I haven't come across.
Old Jan 1, 2010 | 05:20 PM
Bluestreak95
ok so u r saying i shud put a multimeter in the connector that connects to the fan blower n see if there is power running to it...
Old Jan 1, 2010 | 05:26 PM
Bluestreak95
so no power to the blower.......the 40 amp fuze is good also
Old Jan 1, 2010 | 05:44 PM
92dak5.24x4
it's a FUSE and yes you SHOULD put a multimeter on the blower motor wires. But you need to make sure that the key is on, the blower switch is turned on to full and you properly connected the wires after you monkey'd with the connectors. If you would get your hands on a wiring schematic, you can easily trace the wires to see which one should have power then test and verify. Fixing a vehicle requires using rational problem solving skills. Always start with the simple stuff. Make sure you are looking at the correct fuse. Many
Old Jan 1, 2010 | 06:06 PM
Bluestreak95
found the issue...sum dumb **** previous to me wires the blower to the cigarett lighter n the wire is fryed............
