Rear Wiper Removal
Old Jan 12, 2010 | 09:30 AM
ron wilson's Avatar
ron wilson
Default Rear Wiper Removal
Old question but the answer needs repeating, especially this winter. My Dodge Caravan, the rear wiper blade does not exert enough pressure on the window to clean it. I believe the spring in the wiper arm must have gotten too weak to do the job. I would like to know how one goes about removing the wiper arm so that the spring can be lubed or replaced (or the entire wiper arm for that matter). Thanks in advance.
Old Jan 12, 2010 | 09:49 AM
master tech's Avatar
master tech
Site Moderator & Tech
Depends on the year, some had a lock under the joint and some have a nut the holds it down. The one with nut, you need to remove the black cap and take the nut off.
Old Jan 12, 2010 | 09:51 AM
ron wilson's Avatar
ron wilson
Mine is a 2001, I think it has a nut, will look tonight, thx.
Old Jan 12, 2010 | 10:56 AM
circumventor's Avatar
circumventor
y dont yall just lube up all that pivot pts and work it in. i use pb blaster it seems to be best
Old Jan 12, 2010 | 11:25 AM
ron wilson's Avatar
ron wilson
Default Lube it up
I'll try to lub it as best I can. Figured I'd have to remove it to do that effectively.
Old Jan 12, 2010 | 11:31 AM
vabear's Avatar
vabear
Default Wiper Arm
If no nu,t take a close look at the base of the arm where it goes onto the splined shaft and you will see a clip that must be pulled down to unlock he arm.
Old Jan 12, 2010 | 11:54 AM
circumventor
the darn thing moves like 30° on the pivot like the blade can pull away from the glass about 5" if yall can figure out the pull and push on her then thers sumthing wrong. and if she moves ez before lubing then maybe the spring is weak, I seen a bunch of these rear arms bond to the shaft and they had to be cut off with a die grinder so hope yall aint runnning into that prob.
Old Jan 12, 2010 | 12:00 PM
ron wilson's Avatar
ron wilson
I tried to pivot the arm this morning. Without much effort it would only pivot say 5 degrees, less than 1 inch from the glass. If it is capable of pivoting 5 inches then I will try and work it free. Thank you.
Old Jan 12, 2010 | 02:13 PM
circumventor
did is snap back or did yall ahve some ressistance or did it pull ez and snap back?
Old Jan 12, 2010 | 02:28 PM
ron wilson's Avatar
ron wilson
It pulled easy and snapped back, but I only went an inch or so. I'll pull thru the resistance tonight, lube with PB Blaster, and hope that I do not snap the spring. thx for all your advice.
