2001 3.3L Dodge Grand Caravan - Front Oxygen Sensor Replacement
Old Jan 16, 2010 | 10:32 PM
KnuckleHead01's Avatar
KnuckleHead01
Angry 2001 3.3L Dodge Grand Caravan - Front Oxygen Sensor Replacement
I need to replace the oxygen sensor located behind the engine on the exhaust manifold. How is this done???
I have a special socket that is slotted out to fit over the sensor wires, but
can't even get this socket over the sensor, let alone get a ratchet on the socket.
Thinking that I will need to unbolt the exhaust from the manifold to get clear access to this sensor.
Can someone tell me how this is done ???
Old Jan 16, 2010 | 11:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
You can cut the wires off at the sensor and remove the sensor with a 22mm/ 7/8 deep socket. Or a box end wrench. Or find someone with the o2 sensor sensor tool.
Old Jan 17, 2010 | 07:47 PM
soap dodger's Avatar
soap dodger
out of interest, what would this job cost at the dealers?
Old Jan 17, 2010 | 10:42 PM
master tech
What ever is the labor rate for one hour to replace the part, and one hour to pull codes and get a p/a on the part.
