Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
I have a 2005 Grand Caravan, 3.3L engine. When I start the van for the first time of the day, the oil light comes on and stays on. I will switch the engine off and start it back up and the oil light will go off in a normal manner. After the first start of the day, it will not do it again. I keep my oil & filter changed, the correct level is maintained, and I never rev the motor when starting. (Like my grand dad used to do) I have been doing this routine for about a year but now it time to address the problem. What can it be? Oil pump, oil sending unit? Can the oil pump be changed with out removing the motor?
What you may want to do is hook up a pressure gauge and let it sit over night. Start the engine and record ( write down ) the readings. If you are within specs then the problem could be the oil pressure switch.
Dude, that sure seems to be a safe assumption. Can I assume you need a clearly labeled picture of the location, how to remove it and how to properly tighten it? I you over tighten the sender, there is the potential to crack the block
not a bad job? YIKES, that's a wicked job for a novice. speckial crank pulley puller is required. 4.8hr labor time... that indicates a rather involved job.
