Tcm
Old Jan 28, 2010 | 11:23 PM
srt4bad's Avatar
srt4bad
Default Tcm
where is the tcm located on a 2001 GCV with a 3.8l, fwd., auto?
Old Jan 29, 2010 | 06:20 AM
92dak5.24x4's Avatar
92dak5.24x4
Did you look on the driver side frame rail behind the front bumper behind the inner splash shield? thats where I'd look. are you thinking of just tossing in another one?
Old Jan 29, 2010 | 04:45 PM
Tizzy1's Avatar
Tizzy1
REMOVAL
NOTE: If transmission control module is being replaced with a new or replacement unit, the Pinion Factor and Quick Learn procedures must be performed.
  1. Disconnect battery negative cable.
  2. Raise vehicle on hoist.
  3. Remove left front tire/wheel assembly.
  4. Pull back splash shield to gain access to TCM location.
  5. Disconnect TCM 60-way connector.
  6. Remove three (3) TCM-to-rail screws and remove TCM from vehicle.
Old Jan 29, 2010 | 07:21 PM
vabear's Avatar
vabear
Default Tcm
On my '96 it is bolted to the inner fender, engine compartment, passenger side.
Old Jan 29, 2010 | 07:24 PM
92dak5.24x4
Crap, I can't do that job, I cant get past step 2. Now what do I do? Is there some other tool I could use in place of #2?
IDK what a 1996 has to do with this man's post. I guess I could have wrote 'on my 1995 the tcm is on the firewall' but that sure wouldn't do much good for someone with a 1996 where the tcm is on the inner fender in front of the strut tower on the passenger side
Old Jan 29, 2010 | 07:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Miller time.
Old Jan 30, 2010 | 12:16 PM
vabear's Avatar
vabear
Default Miller Time
Ein Pils Bitte
