91 Grand caravan speedo broken
Old Feb 8, 2010 | 05:53 PM
gregdell1121's Avatar
gregdell1121
Default 91 Grand caravan speedo broken
I have a 1991 grand caravan 3.3L AWD and recently the speedometer and odometer stopped working and i need to fix it to pass inspection. I have already replaced both input and output speed sensors, checked both plugs for continuity, checked the speedometer moter itself and it is good. Still not working. Any ideas or steps i should take to diagnose something else as the problem would be much appreciated. Thanks
Old Feb 9, 2010 | 12:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
1993 was the first year the speed sensor was also the output sensor. The early a604 trans (1989 to 1992) had a speed sensor. You will find the speed sensor on the all wheel driver unit. So you really have three sensors.
Old Feb 9, 2010 | 12:19 PM
gregdell1121
ok thanks a lot, ill try that
