2004 Dodge Caravan Code P2302 HELP!!
Old Feb 8, 2010 | 10:14 PM
saltycajun's Avatar
saltycajun
Default 2004 Dodge Caravan Code P2302 HELP!!
3.3L Runs rough at idle and starts dropping out if you rev engine higher. I don't have all the cool tools listed in the Diagnostic Procedures for Code P2302. So, I changed the plugs, ignition wires (one so corroded it broke at the boot), and ignition coil. Nothing changed, same poor running condition. Erased code and same one re-appeared after starting it up. Just not sure if I should venture out and buy a PCM from ebay or admit defeat and hire someone to troubleshoot. Any ideas would greatly be appreciated..
Thanks,
Byron
Old Feb 9, 2010 | 12:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
Ck the wire harness around the intake manifold for any wires melted. You may have an open wire. And you may need to take it to a shop.
Old Feb 15, 2010 | 11:26 AM
saltycajun's Avatar
saltycajun
Default Thanks!!
You were right. Took it to the dealership. They found burnt wires and said the computer needed to be replaced as well.
