brake lights
Old Feb 14, 2010 | 07:12 PM
greywolf03's Avatar
greywolf03
Default brake lights
2007 caravan 3rd brake is burned out. brake light on staying on. i changed the 3rd brake light bulb and other ones goes out. Why the dodge place i went to does not know why and cost my around 100.00 to found out this
thank you in advandes
Old Feb 14, 2010 | 07:16 PM
Dodge Tech's Avatar
Dodge Tech
what other light are u talking about? are they still on?
Old Feb 14, 2010 | 07:20 PM
greywolf03's Avatar
greywolf03
the main taillight brake light staying on when the 3rd brake light is burned out or the no bulb in it
Old Feb 14, 2010 | 07:22 PM
Dodge Tech's Avatar
Dodge Tech
that still did not answers anything the 3rd brake light burnt out u replaced it then what? U have 3 brake lights one on each side and one in the middle u replaced the one in the middle and what after that?
Old Feb 14, 2010 | 07:30 PM
greywolf03's Avatar
greywolf03
3rd brake is burned out or has no bulb and main tailight brake light stays on and then change the 3rd brake light bulb and then the main brake light goes out
Old Feb 14, 2010 | 07:37 PM
Dodge Tech's Avatar
Dodge Tech
never mind see if some one else will help you out.
Old Feb 14, 2010 | 07:44 PM
greywolf03's Avatar
greywolf03
i have 3 brake lights one on each side and one in the middle. the one in the middle is burned out and one on each side stay when change one in middle and one on each side goes out
Old Feb 14, 2010 | 09:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
You have a total of 5 brake lite bulbs. One on the driver side, one on the passenger side and 3 in the middle which would the 3rd brake! Are all the lites staying on now. If they are pull up on the brake pedal or disconnect the brake switch.
Old Feb 15, 2010 | 10:01 AM
greywolf03's Avatar
greywolf03
one on driver side and one on passenger side and one in the middle.the one in the middle was burned out and ones on the driver and passenger side was staying on.the middle one was changed then one on the driver and passenger side went out. it happens when the middle one has on bulb in too
Old Feb 15, 2010 | 02:46 PM
master tech
Then the brake lites are off now, or you mean when you replace the 3rd brake lite bulbs the others ones burnt out too?
