Alternator issue
Old Feb 18, 2010 | 12:01 PM
map79z28's Avatar
map79z28
Default Alternator issue
I have a 97 Grand Caravan, 200K+, 3.3L. Yesterday the battery light came on. I discovered that it comes on when I have the defogger on for a long time. When I turn the defogger off, the light goes out after a few minutes. Also, when I start it up, it is not on. I went to Autozone to have it checked out and it came up as having a bad diode and was putting out 89.4 amps and the battery light was not on. My question though, is can I replace this with a 120 amp alternator? I think that I have a 90 amper since I do not have the rear heater stuff. I'd appreciate any replies. Thanks!
Old Feb 18, 2010 | 12:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Sure you can, the 120 amp alternator will give 98 amps where the other one gives you only 86 amps.
Old Feb 18, 2010 | 12:41 PM
map79z28's Avatar
map79z28
Thanks for the reply. So does that mean that I have a 120 amper? The measured amps at Autozone was 89.4 - which is lower than 98, but higher than 86. I havent measured the casing, which is the other way to determine the amps.
Old Feb 18, 2010 | 12:54 PM
master tech
That means the 120 amp alternator puts out 98 ampere and the 90 amp puts out 86 ampere.
