mil codes for 2001 to 2007 diesel
Old Feb 18, 2010 | 05:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default mil codes for 2001 to 2007 diesel
DIAGNOSTIC INFORMATION
DRIVEABILITY - DIESEL
P0100-MASS AIR FLOW SENSOR PLAUSIBILITY
P0100-MASS AIR FLOW SENSOR PLAUSIBILITY POSITIVE AREA.
P0100-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO HIGH
P0100-MASS AIR FLOW SENSOR SIGNAL VOLTAGE TOO LOW
P0100-MASS AIR FLOW SENSOR SUPPLY VOLTAGE TOO HIGH OR LOW
P0105-BAROMETRIC PRESSURE CIRCUIT SIGNAL VOLTAGE TOO HIGH
P0105-BAROMETRIC PRESSURE CIRCUIT SIGNAL VOLTAGE TOO LOW
P0606-ECM ERROR GATE ARRAY - COMMUNICATION
P0606-ECM ERROR GATE ARRAY - COMMUNICATION NOT VERIFIED
P0606-ECM ERROR GATE ARRAY - QUANTITY STOP
P0606-ECM ERROR RECOVERY HAS OCCURRED
P0606-ECM ERROR REDUNDANT OVERRUN MONITORING
P1206-CALCULATED INJECTOR VOLTAGE TOO HIGH.
P1206-CALCULATED INJECTOR VOLTAGE TOO LOW
P1601-CAPACITOR VOLTAGE 1 VOLTAGE TOO HIGH
P1601-CAPACITOR VOLTAGE 1 VOLTAGE TOO LOW
P1602-CAPACITOR VOLTAGE 2 VOLTAGE TOO HIGH
P1602-CAPACITOR VOLTAGE 2 VOLTAGE TOO LOW
P1606-AFTER RUN SHUT OFF ERROR-INJECTION POWERSTAGE
P1606-AFTER RUN SHUT OFF ERROR-ZERO QUANTITY
P1610-VOLTAGE REGULATOR SIGNAL VOLTAGE TOO HIGH
P1610-VOLTAGE REGULATOR SIGNAL VOLTAGE TOO LOW
P1680-EEPROM PLAUSIBILITY CHECKSUM ERROR
P1680-EEPROM PLAUSIBILITY CODE WORD INCORRECT OR MISSING
P1680-EEPROM PLAUSIBILITY COMMUNICATION ERROR
P1680-EEPROM PLAUSIBILITY VARIATION NUMBER ERROR
P1680-EEPROM PLAUSIBILITY VIN CHECKSUM ERROR
P1680-EEPROM PLAUSIBILITY WRITE ERROR
P1685-SKIM SYSTEM INVALID SECRET KEY IN EEPROM
P1685-SKIM SYSTEM WRITE ACCESS TO EEPROM FAILURE
P0110-INTAKE AIR TEMP SENSOR CIRCUIT SIGNAL VOLTAGE TOO HIGH
P0110-INTAKE AIR TEMP SENSOR CIRCUIT SIGNAL VOLTAGE TOO LOW
P0111-INTAKE AIR TEMP SENSOR PLAUSIBILITY
P0115-ENGINE COOLANT TEMP SENSOR CIRCUIT ENGINE IS COLD TOO
LONG
P0115-ENGINE COOLANT TEMP SENSOR CIRCUIT SIGNAL VOLTAGE TOO
HIGH
LOW
P0190-FUEL PRESS SENSOR CIRCUIT MALF SIGNAL VOLTAGE TOO HIGH.
P0190-FUEL PRESS SENSOR CIRCUIT MALF SIGNAL VOLTAGE TOO LOW
P0190-FUEL PRESS SENSOR CIRCUIT MALF SUPPLY VOLTAGE TOO HIGH OR
LOW.
P0201-CYLINDER 1-INJECTOR CIRCUIT CURRENT DECREASE
P0201-CYLINDER 1-INJECTOR CIRCUIT LOAD DROP
P0201-CYLINDER 1-INJECTOR CIRCUIT OVERCURRENT HIGH SIDE.
P0201-CYLINDER 1-INJECTOR CIRCUIT OVERCURRENT LOW SIDE
P0202-CYLINDER 2-INJECTOR CIRCUIT CURRENT DECREASE
P0202-CYLINDER 2-INJECTOR CIRCUIT LOAD DROP
P0202-CYLINDER 2-INJECTOR CIRCUIT OVERCURRENT HIGH SIDE
P0202-CYLINDER 2-INJECTOR CIRCUIT OVERCURRENT LOW SIDE
P0203-CYLINDER 3-INJECTOR CIRCUIT CURRENT DECREASE
P0203-CYLINDER 3-INJECTOR CIRCUIT LOAD DROP
P0203-CYLINDER 3-INJECTOR CIRCUIT OVERCURRENT HIGH SIDE
P0203-CYLINDER 3-INJECTOR CIRCUIT OVERCURRENT LOW SIDE
P0204-CYLINDER 4-INJECTOR CIRCUIT CURRENT DECREASE
P0204-CYLINDER 4-INJECTOR CIRCUIT LOAD DROP
P0204-CYLINDER 4-INJECTOR CIRCUIT OVERCURRENT HIGH SIDE.
P0204-CYLINDER 4-INJECTOR CIRCUIT OVERCURRENT LOW SIDE
P0235-BOOST PRESSURE SENSOR PLAUSIBILITY
P0235-BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO HIGH
P0235-BOOST PRESSURE SENSOR SIGNAL VOLTAGE TOO LOW
P0235-BOOST PRESSURE SENSOR SUPPLY VOLTAGE TOO HIGH OR LOW
P0243-TURBOCHARGER WASTEGATE SOL CKT NEGATIVE DEVIATION
P0243-TURBOCHARGER WASTEGATE SOL CKT POSITIVE DEVIATION
P0243-TURBOCHARGER WASTEGATE SOL CKT OPEN CIRCUIT
P0243-TURBOCHARGER WASTEGATE SOL CKT SHORT CIRCUIT
P0335-CKP POSITION SENSOR CIRCUIT OVERSPEED RECOGNITION
P0340-CMP/CKP POSITION SENSOR CIRCUIT - CKP DYNAMIC PLAUSIBILITY
P0340-CMP/CKP POSITION SENSOR CIRCUIT - CKP STATIC PLAUSIBILITY
P0340-CMP/CKP POSITION SENSOR CIRCUIT - CMP DYNAMIC PLAUSIBILITY
P0340-CMP/CKP POSITION SENSOR CIRCUIT - CMP SIGNAL FREQUENCY TOO
HIGH
P0340-CMP/CKP POSITION SENSOR CIRCUIT - STATIC PLAUSIBILITY
P0340-CMP/CKP POSITION SENSOR CIRCUIT - CMP/CKP SYNC FAILURE
P0380-GLOW PLUG CIRCUIT A OPEN CIRCUIT
P0380-GLOW PLUG CIRCUIT A SHORT CIRCUIT
P0403-EGR SOLENOID CIRCUIT OPEN CIRCUIT
P0403-EGR SOLENOID CIRCUIT SHORT CIRCUIT
P0480-FAN 1 CONTROL CIRCUIT OPEN CIRCUIT
P0480-FAN 1 CONTROL CIRCUIT SHORT CIRCUIT
P0481-FAN 2 CONTROL CIRCUIT OPEN CIRCUIT
P0481-FAN 2 CONTROL CIRCUIT SHORT CIRCUIT
P0487-EGR AIR FLOW CONTROL VALVE SHORT CIRCUIT
P0487-EGR AIR FLOW CONTROL VALVE SHORT TO GROUND
P0500-VEHICLE SPEED SENSOR FREQUENCY TOO HIGH
P0500-VEHICLE SPEED SENSOR HIGH LEVEL DURATION
P0500-VEHICLE SPEED SENSOR PLAUSIBILITY
P0500-VEHICLE SPEED SENSOR SIGNAL VOLTAGE TOO HIGH
P0514-BATTERY TEMP SENSOR CIRCUIT SIGNAL VOLTAGE TOO HIGH
P0514-BATTERY TEMP SENSOR CIRCUIT SIGNAL VOLTAGE TOO LOW
P0520- OIL PRESS SENSOR CIRCUIT MALF PLAUSIBILITY
P0520-OIL PRESS SENSOR CKT MALF SIGNAL VOLTAGE TOO HIGH
P0520-OIL PRESS SENSOR CKT MALF SIGNAL VOLTAGE TOO LOW.
P0520-OIL PRESS SENSOR CKT MALF SUPPLY VOLTAGE TOO HIGH OR LOW
P0530-A/C PRESSURE SENSOR CIRCUIT PLAUSIBILITY
P0530-A/C PRESSURE SENSOR CIRCUIT SIGNAL VOLTAGE TOO HIGH
P0530-A/C PRESSURE SENSOR CIRCUIT SIGNAL VOLTAGE TOO LOW
P0530-A/C PRESSURE SENSOR CIRCUIT SUPPLY VOLTAGE TOO HIGH OR
LOW.
P0560-SYSTEM VOLTAGE TOO HIGH
P0560-SYSTEM VOLTAGE TOO LOW
*CHECKING THE CHARGING SYSTEM OPERATION
P0579-S/C SWITCH SIGNAL CIRCUIT PLAUSIBILITY
P0579-S/C SWITCH SIGNAL CIRCUIT SIGNAL VOLTAGE TOO HIGH
P0579-S/C SWITCH SIGNAL CIRCUIT SIGNAL VOLTAGE TOO LOW
P0615-STARTER RELAY CIRCUIT SHORT CIRCUIT
P0620-GENERATOR FIELD CONTROL MALF OPEN CIRCUIT
P0620-GENERATOR FIELD CONTROL MALF SHORT CIRCUIT
P0620-GENERATOR FIELD CONTROL MALF UNSTABLE CURRENT
P0627-FUEL LIFT PUMP RELAY CONTROL CIRCUIT OPEN CIRCUIT
P0627-FUEL LIFT PUMP RELAY CONTROL CIRCUIT SHORT CIRCUIT
P0641-SENSOR REFERENCE VOLTAGE A CKT VOLTAGE TOO HIGH
P0641-SENSOR REFERENCE VOLTAGE A CKT VOLTAGE TOO LOW
P0645-A/C CLUTCH RELAY CIRCUIT OPEN CIRCUIT
P0645-A/C CLUTCH RELAY CIRCUIT SHORT CIRCUIT
P0651-SENSOR REFERENCE VOLTAGE B CKT VOLTAGE TOO HIGH
P0651-SENSOR REFERENCE VOLTAGE B CKT VOLTAGE TOO LOW
P0685-ECM/PCM RELAY CONTROL CIRCUIT SHUTS OFF TOO EARLY
P0685-ECM/PCM RELAY CONTROL CIRCUIT SHUTS OFF TOO LATE
P0700-TCM DTC
P0703-BRAKE SWITCH SIGNAL CIRCUITS PLAUSIBILITY WITH REDUNDANT
CONTACT
P0703-BRAKE SWITCH SIGNAL CKTS PLAUS W/REDUNDANT CONTACT AFTER
INITIALIZATION.
P0833-CLUTCH PEDAL PLAUSIBILITY
P0864-TORQUE MANAGEMENT REQUEST FAULT
P1130-FUEL RAIL PRESSURE MALFUNCTION LEAKAGE DETECTED.
P1130-FUEL RAIL PRESSURE MALFUNCTION PRESSURE TOO HIGH-SHUT
OFF
P1130-FUEL RAIL PRESSURE MALFUNCTION PRESSURE TOO LOW
P1130-FUEL RAIL PRESSURE MALFUNCTION SOLENOID OPEN
P1131-FUEL PRESSURE SOLENOID OPEN CIRCUIT
P1131-FUEL PRESSURE SOLENOID PLAUSIBILITY IN AFTER-RUN
P1131-FUEL PRESSURE SOLENOID SHORT CIRCUIT
P1511-BATTERY SENSE LINE 1 VOLTAGE TOO HIGH
P1511-BATTERY SENSE LINE 1 VOLTAGE TOO LOW
P1512-BATTERY SENSE LINE 2 VOLTAGE TOO HIGH
P1512-BATTERY SENSE LINE 2 VOLTAGE TOO LOW
P1605-IGNITION SWITCH PLAUSIBILITY
P1651-MIL/DIAG LAMP VIA J1850 BUS IN FRAME RESPONSE ERROR
P1651-MIL/DIAG LAMP VIA J1850 BUS STATUS ERROR .
P1652-J1850 COMMUNICATION BUS RECEIVE TIMEOUT
P1652-J1850 COMMUNICATION BUS SHORT TO GROUND
P1652-J1850 COMMUNICATION BUS SHORT TO VOLTAGE
P1652-J1850 COMMUNICATION BUS SPI ERROR.
P1652-J1850 COMMUNICATION BUS TRANSMIT BUFFER OVERRUN
P1652-J1850 COMMUNICATION BUS UNAUTHORIZED RESET
P1685-SKIM SYSTEM INVALID KEY CODE RECEIVED
P1685-SKIM SYSTEM KEY COMMUNICATION TIMED OUT
P1685-SKIM SYSTEM SKIM ERROR .
P2120-ACC PEDAL POSITION SENSOR 1 CKT PLAUSIBILITY
P2120-ACC PEDAL POSITION SENSOR 1 CKT PLAUSIBILITY WITH BRAKE
SWITCH.
P2120-ACC PEDAL POSITION SENSOR 1 CKT PLAUSIBILITY WITH LOW IDLE
SWITCH
POTENTIOMETER
P2120-ACC PEDAL POSITION SENSOR 1 CKT SIGNAL VOLTAGE TOO HIGH
P2120-ACC PEDAL POSITION SENSOR 1 CKT SIGNAL VOLTAGE TOO LOW
P2120-ACC PEDAL POSITION SENSOR 1 CKT SUPPLY VOLTAGE TOO HIGH OR
LOW
U1421-IGNITION KEY OFF TIMER PERFORMANCE - TIMER TOO FAST
U1421-IGNITION KEY OFF TIMER PERFORMANCE - TIMER TOO SLOW
i
