2007 Grand Caravan pass airbag on/off switch
Old Feb 25, 2010 | 07:58 PM
mattsauto's Avatar
mattsauto
Default 2007 Grand Caravan pass airbag on/off switch
How do you turn the pass. side air bag off? There's the indicator light that reads "Pass Airbag On". Can you even turn it off?
Old Feb 25, 2010 | 09:58 PM
blackstone's Avatar
blackstone
I don't believe you can turn it off manually.
The light on means there is something malfunctioning with your airbag, you should go check it out.
I also have a 2007 Dodge Caravan and both my driver & passenger lights are on, so Im going to go head to the dealer to have them reset.
Use the search function in the forum, this issue was brought up many times.
Old Feb 26, 2010 | 11:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
You can't turn the passenger air bag lite off. the ram trucks could. But not the minivans.
Old Feb 27, 2010 | 03:55 PM
mattsauto's Avatar
mattsauto
Default clarify and thanks
I guess I should clarify the issue. The light that is on is not the airbag warning light, but the "Pass. Airbag Off" light above the center vents (I think, It's my sister's van, my 03 does not have this).
My bro-n-law found out that apparently there is a weight sensor in the pass. seat that senses a passenger of a certain weight. Apparently there is a small window of weight that will switch the sensor off. Can anyone confirm this? Also, what is the weight "window"?
Thanks,
