Dodge caravan sxt 2010 remote start
Old Feb 27, 2010 | 09:39 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
Default Dodge caravan sxt 2010 remote start
ok i have a remote start from factory that acts up sometimes. i hit it to start (2X) it will beep once not the reqular 2 times and thats it. only time i find i fix this if i go into vehicle and start it and turn it off then close doors and then retry it will start. anyone experience this?
Old Feb 27, 2010 | 03:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
No i haven't. I would have the dealer ck for codes and ck the switch under the hood too.
Old Feb 28, 2010 | 10:19 AM
DodgeCaravan2010SXT
its weird cause it done this about 3 to 4 times. not always it repeats. seems when it is left for a period time cause we hardly lately drive that much when it happens more often. kinda screws up the idea if ya got to start it manual and then turn it off and then close doors and all good after that.
Old Dec 9, 2014 | 10:51 AM
cschmidt's Avatar
cschmidt
I purchased a 2010 Dodge Caravan Crew yesterday. Remote start worked at the dealer. I tried to use it this morning and had the exact symptoms you describe. One beep and the doors locked. Did not start. Jumped in started it and drove it 5 miles to work. Turned it off and started it using the remote start twice when I got out. Went in to work and came out for break time two hours later and tried to use remote start, same thing. One beep and the doors lock. After starting manually tried again and again it works. Frustrating. Any advice on this? Did you ever get your issue resolved?
Old Dec 9, 2014 | 11:51 AM
DodgeCares's Avatar
DodgeCares
Have you contacted the servicing dealer to advise of the issue since you just purchased the vehicle?
Old Dec 9, 2014 | 12:14 PM
cschmidt's Avatar
cschmidt
Nope. Purchased As-Is, assuming they would just ask me to bring it in. As it is more than an hour from where I live, it's not the most attractive option. I'll call and ask, just thought this would be a good place to look for a fix before taking it in as I like to fix things myself whenever possible.
Old Dec 9, 2014 | 03:58 PM
DodgeCaravan2010SXT
to be honest has not acted up again. went away.
Old Dec 10, 2014 | 11:40 AM
cschmidt's Avatar
cschmidt
Thanks for the response! I continued to research the issue on forums and such and also emailed the dealer. Turns out that if the low fuel light is on it interferes with the remote start feature. Not sure why it doesn't always prevent remote start, but filled up the tank and now it seems to work. It's only been 1 day so far but I'm optimistic that this was the issue. Anyone having this issue should try filling the gas tank first as an easy fix.
Old Dec 10, 2014 | 12:06 PM
Doneworking's Avatar
Doneworking
Yes that is the way it works. Had it happen to me a couple of times. Smart design.
Old Jan 12, 2018 | 07:45 PM
larryes's Avatar
larryes
had a similar problem with a new yorker several years ago it was the anti thieft system
