Question? ATF Filter for Caravan 3.3L (2004)
Old Mar 22, 2010 | 12:38 PM
jkimchi's Avatar
jkimchi
Default Question? ATF Filter for Caravan 3.3L (2004)
Hoping someone can assist regarding a question about the Automatic Transmission Filter for the 3.3L V6 Caravan (2004, with 92,500km).
Since having purchased the minivan used (at 65,000km), I have not opened up the transmission for a fluid/filter change (although I had the dealer do a pan drop and filter change at 75,000km).
My questions are:
  • Is the filter attached to the valve body/fluid pump by a TORX 25 (T25) screw?
    Or is the filter simply snapped into place and kept into place via the o-ring?
  • Also, if I researched this correctly, what is the correct procedure for mounting the filter?Does the o-ring get placed in the valve body/fluid pump and then the filter put on,
    Or do you stick the o-ring on the filter and put the filter on the valve body/fluid pump (I hear the latter may damage the transmission.
Clarification on both these elements above would be greatly appreciated.
Cheers!
Old Mar 22, 2010 | 09:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
When you replace the filter, put the o-ring on the filter first. The filter just snaps into place on the valve body.
