how to Gravity Bleed/Flush Brakes
Old Mar 26, 2010 | 07:58 PM
trophyslayer's Avatar
trophyslayer
Default how to Gravity Bleed/Flush Brakes
2006 Dodge Grand Caravan v6 3.8L
32oz dot 3 brake fluid
Long funnel to reach Master cylinder
some 1/4" interior diameter plastic tubing, 1-2 feet
3/8" box end wrench
empty plastic bottle
turkey baster or I used my homemade suction pump
rags
bleeding order for My vehicle is Drivers rear, Passenger Front, Passenger Rear, and Drivers Front, Per Tizzy1
this method does not touch the brake pedal at all, is slow but works and low risk, brake fluid can take paint off so be careful
step 1. drain most of the fluid from master cylinder using turkey baster or pump
refill to top, then drain again and refill to help clean master cylinder fluid, can repeat again if fluid is very dark, end with the master cylinder filled to the top and cap on, I had to add some plastic tubing to the bottom of my funnel because the location of the Master cylinder would not allow my funnel to sit and be filled with out a risk of spilling
step 2 I found it easier to remove the rear tires to access the bleeder valves, the front tires I could access by turning the wheel all the way to the side I was working on,
wipe off around rubber cover, then pull to remove, get your 3/8" box end wrench and try to loosen it 1/4 turn, Make sure you are turning it the right way, if it doesn't move try some Pb blaster and let sit a few mins, once you know you can open it, then turn it closed but not tight, attach your plastic tubbing to your valve, place a rag under the valve, then using either your finger or a pair of pliers loosen the bleeder valve 1/4 to 1/2 turn, and fluid will slowly start to drip out, you may have to open the cap of the master cylinder and put it back on or leave it off, mine worked with the cap on, but every now and then I had to pull the cap off, and keep an eye on the master cylinder so it doesn't run out of fluid
step 3, once the color changes to the new fluid, you will then turn the valve closed and pull off your tubbing, and go to the next wheel, I let my first valve bleed for about 1hr, didn't need to do it that long, but my fluid was not that dirty so it was hard to tell when it changed color, they do sell some Blue and red brake fluid, may be a better choice
total time to do all 4 wheels and rotated tires was 2hrs,
Note, after done, pump the brake pedal several times to build up pressure
refillingmasterclyinder.jpg?t=1269647389
refilling the Master cylinder after draining
rearbrakesbleedervalvewithcoveron2.jpg?t=1269647389
bleed valve with rubber cover on
rearbrakesbleedervalvewithcoveron.jpg?t=1269647391
rubbercover.jpg?t=1269647397
rubber bleed valve cover, Don't lose it
rearbrakesbleedvalverubbercoverremo.jpg?t=1269647423
bleed valve with rubber cover removed
rearbrakesgravitybleedingonly.jpg?t=1269647429
plastic tubbing with rag under it in case of drips, going into a jug, or in my case my homemade suction pump that I hook up to a shop vac to suck fluid out, example the master cylinder
fontbrakesoldfluiddraining.jpg?t=1269647433
old fluid in from front wheels, don't have to remove the tires on the front
Old Mar 26, 2010 | 11:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Good job. Do you mind if i move this to the DIY section?
Old Mar 27, 2010 | 08:21 AM
trophyslayer
nope feel free too
Old Mar 27, 2010 | 09:07 AM
Tizzy1's Avatar
Tizzy1
Looks like you had fun, nice job
Old Mar 27, 2010 | 09:26 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
recommend like doing it like every 40km. they recommen dot3 but can use dot 4 think dot4 a better brake fluid?
Old Mar 27, 2010 | 10:04 AM
Tizzy1's Avatar
Tizzy1
Dot 4 is synthetic, you don't want to mix the two. If it has 3, use 3.
Old Mar 27, 2010 | 02:10 PM
trophyslayer
yup, wasn't hard, took some time but was able to do other things while it drained, and there is very little risk at getting the Master cylinder to run out of fluid at the speed it goes,
i even had my 2 1/2 year old son helping be rotate the tires, he would sit there and hand me the lug nuts, but mainly he just hit some wrenches together
